Results 1 to 2 of 2
  1. #1
    Default "I started and stopped the eng
    "I started and stopped the engine all day and when I got back to the dock turning the key did nothing. I pulled it to the trailer and was able to trim up and get it home. I replaced the starter and it clicked once. I have no gauge power, radio or accessories. All I can do is trim. I've checked the obvious stuff. If anyone can help me out with what to do next I'd appreciate it."
  2. #2
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Default Shove the main breaker "RE
    Shove the main breaker "RED RESET" button in. Sounds like ignition switch and/or slave solenoid. First verify your battery cables are clean and tight on BOTH ends of BOTH cables.
    Fix minor things (replace wear items for preventative maintenance.) that cause major problems before they break.
Similar Threads
  1. Power Trim Electrical Issue 2002 50 hp
    By mark45053 in forum Mercury Mariner Outboard Forum
    Last Post: 04-12-2010, 01:50 PM
  2. Power tilt trim mercruiser 30
    By landonandtrenton in forum Miscellaneous marine engine topics
    Last Post: 03-16-2010, 08:12 AM
  3. Mercruiser 2000 Power Trim Reservoir Where is it located
    By minnesota in forum Mercruiser Sterndrive Archive
    Last Post: 07-30-2009, 01:09 AM
  4. Mercruiser power trim oil
    By baba_bluey in forum Mercruiser Sterndrive Archive
    Last Post: 03-10-2009, 11:05 PM
  5. 1991 Mercruiser 350 Magnumno power
    By puzzolente in forum Mercruiser Sterndrive Archive
    Last Post: 07-22-2008, 10:51 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
