MarineEngine.com - Your online store for all types of marine engines and boat parts.
PHONE ORDERS
Monday - Friday
9:00 AM - 5:00 PM EST
Click for TOLL-FREE Number
Secure Online Payments
Special $9.95 Flat Rate Shipping
(800) 209-9624 | Home | Contact | Shipping | Returns | Cart View your shopping cart.
Search by Part Number
Enter engine/drive part number.
Original & matching parts for sale.
Manuals & Accessories
Shop by description, item number
or manufacturer's model number.
Why shop with us? Check our reviews! Why Us & Reviews   Boat Repair Forum Boat Repair Forum   Boat Video Gallery Video Gallery
Results 1 to 7 of 7
  1. #1
    Join Date
    Jun 2008
    Location
    Pearlington, MS, USA
    Posts
    13
    Default I have a 88 King Cobra 460. It
    I have a 88 King Cobra 460. It's getting water in one of the cylinders & in the oil. These symptoms tell me blown head gasket. I pull the plugs & proceed to check compression. All seems good on the compression test 95-105psi across the board. Anyone have any ideas as to how i can have a leak & such good compression?
  2. #2
    Default "Is your engine in this attach
    "Is your engine in this attachement? It should be. My guess is your compression should be 150-160."
  3. #3
    Join Date
    Jun 2008
    Location
    Posts
    13
    Default "Well, I took the heads off. H
    "Well, I took the heads off. Had them checked, then re-installed them with new gaskets. Crank it up & same problem as before. Plenty of compression & runs, but still getting water in oil. I'm guessing it must be a cracked block. My internals are still good the motor only has about 200 hrs on it. Anyone know where to find a good empty 460 block for cheap?
    Thanks, Landon."
  4. #4
    Join Date
    May 2007
    Location
    Kawarthas
    Posts
    3,203
    Default 90% of water in oil problems a
    90% of water in oil problems are due to failing exhaust manifoldsm with the exception being motors that are not winterized in cold climates
    Factory Manual Best, Seloc 2nd best, Clymer if you're desperate.
  5. #5
    Join Date
    Jun 2008
    Location
    Posts
    13
    Default The boat came from the FL panh
    The boat came from the FL panhandle so I doubt winterizing was a concern. Should I flush the oil & try running it without water going to the manifolds to see if the problem persists? I do however understand that I will be limited as to how long I can run it...
    Thanks!
  6. #6
    Join Date
    Aug 2007
    Location
    England
    Posts
    65
    Default "Wot ever you do, do not run i
    "Wot ever you do, do not run it without water supply. It will wreck your water pump impellor in seconds."
  7. #7
    Join Date
    Jun 2008
    Location
    Posts
    13
    Default "Yes, I'm aware of that! T
    "Yes, I'm aware of that! Thanks!"
Similar Threads
  1. Not sure how to proceed. Blown head gasket, head or worse...
    By Philster in forum Mercruiser Sterndrive Forum
    Last Post: 08-17-2010, 06:08 PM
  2. can blown head gasket cause low/no oil pressure? 1999 7.4 L
    By stuffdogg in forum Mercruiser Sterndrive Forum
    Last Post: 07-28-2010, 12:06 PM
  3. Oil pressure and a blown head gasket
    By srdancer90 in forum Mercruiser Sterndrive Archive
    Last Post: 08-26-2008, 10:12 PM
  4. Blown head gasket
    By Brandon Wojcik in forum Volvo Penta Gas Archive
    Last Post: 05-17-2007, 12:40 PM
  5. Blown head gasket
    By Will C. in forum OMC Sterndrive and Inboard Archive
    Last Post: 04-27-2006, 06:42 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
