"John, I don't know the ex
"John, I don't know the exact compression numbers. What your looking for is numbers that are close together from cylinder to cylinder. I think a compression reading with numbers deviating less that ten pounds is good. But it is possible to get even compression readings below 90lbs compression. Below 90lbs is pretty much worn out by my standards. This would mean the cylinder walls and rings are shot. Try looking for an online manual and see if these compression readings are listed in the spec section of the manual. I'm pretty sure Tohatsu.com has online manuals that you can download.
Mark."
