"I just installed a new stator
"I just installed a new stator and trigger,,engine ran rough and hard to start the same before installation,,,I replaced the stator and trigger due to corroding wires.
The fly wheel can only be installed one way as there is a spline small splines then large spline ,no seperate key to line up the flywheel.
Started it up,,hard to start,,then ran rough,,I noticed the fuel filter is trasparent and the fuel was below the inlet and outlet ends I had to pump bulb to get the fuel up where I thought it should be. I took the front cover off and turned the carb adjustments back a quarter or so a turn,,it seemed to run smoother but the rev's got higher also,,so I adjusted them back the way they were till I could get more info on it.I found TDC on #1 piston and where the timing marks are it was on the zero
Any body have suggestions??
Thanks in advance,,,Mike"
