MarineEngine.com - Your online store for all types of marine engines and boat parts.
Order by phone
(800) 209-9624
Monday - Friday
8:30 AM - 5:30 PM EST
Safe Online Orders
Comodo Enhanced Security
Special $9.95 Flat Rate Shipping
Boat Repair Forum Boat Repair Forum     Boat Video Gallery Video Gallery
Home | Contact | Shipping | Returns | Cart View your shopping cart.
Part Number Search
Shop by engine/drive part number.
Original & matching parts for sale.
Manuals & Accessories
Shop by description, item number
or manufacturer's model number.
Results 1 to 5 of 5
  1. #1
    PAUL JAWOR's Avatar
    PAUL JAWOR Guest
    Default " JOE-HAVE NO POWER AT TAKE OF
    " JOE-HAVE NO POWER AT TAKE OFF. ONLY RUNS TO 4000 RPM.POWER PACK JUST REBUILT LAST WEEK.TOOK TWO MONTHS TO FIX,PART BACKORDERED? CARBS WERE REBUILT TWO MONTHS BEFORE.GET SPARK AT ALL CYLINDERS,100 COM. ALL CYLINDERS.PUT NEW PLUGS IN,RAN ENGINE. 4 PLUGS HAD SOME CARBON DEPOSITS,TWO PLUGS HAD NONE? JUST THE TIPS OF THE 2 PLUGS LOOKED USED.PLEASE HELP,COSTING LOT OF MONEY! DEALER WERE P/PACK REBUILT SAYS CARBS NEED
    TO BE REBUILT,GAS USED NOWADAYS IS NO GOOD! GOES BAD FAST! "
  2. #2
    Join Date
    Feb 2001
    Posts
    10,711
    Default "Paul... Sounds like you'r
    "Paul... Sounds like you're only obtaining power on four cylinders. If you've got good compression and spark that will jump a 7/16 gap (with the s/plugs out) on all cylinders, the problem would have to be fuel related. YOu say that the engine took two months to be fixed and that the carbs were rebuilt two months before that... means that the carbs have been sitting for four (4) months. They could foul in that length of time.
    Remove the large black plastic carburetor face plate and start the engine. With the engine running, stick two fingers in the top left carburetor throat which will act like a choke, then repeat the process with the right top throat, center left throat etc etc. The engine will have a tendency to slow down on the carbs that are okay... but will increase in rpms when you do the carb that's fouled. Clean that one. Keep me informed.
    Curious.... you had the p/pack rebuilt or simply replaced?
    Joe[img][/img]"
    Our questions require answers. If you refuse to answer our questions, how can we answer yours?
  3. #3
    gregg's Avatar
    gregg Guest
    Default " While reading this message I
    " While reading this message I couldn't help but ask about my 1990 115hp evinrude. after trolling for a bit I loose all throttle response so full throttle is the same as 1/4 throttle. This lasts between a few seconds and a few minutes. Serviced all fuel system including carbs, changed plugs, now wondering if it might be electrical like trigger or power pack. This only started a few weeks ago and never happens right when I go out. Any help would be greatly appreciated. thanks Gregg "
  4. #4
    Default " JOE-RAN ENGINE TESTED WITH T
    " JOE-RAN ENGINE TESTED WITH TWO FINGERS IN EACH
    CARB THROAT. THE TOP LEFT ONE INCREASED IN POWER
    A FEW SECONDS THEN FELT FUEL ON FINGERS AN ENGINE
    SLOWED DOWN,DID SAME THING TO SECOND CARB ON RIGHT
    RPM'S WENT UP,NO FUEL FELT ON FINGERS IN THROAT.
    WILL TAKE THAT CARB APART TODAY! P/PACK I THINK
    WAS SENT OUT TO BE REBUILT! PAUL "
  5. #5
    Default " JOE-TOOK THE TWO CARBS APART
    " JOE-TOOK THE TWO CARBS APART. CLEANED JETS,FOUND
    FLOATS WERE WAY OFF ON ADJUSTMENT.INSTEAD OF BEING
    PARALLEL, THE FLOATS WERE OFF BY ALMOST 1" ON BOTH
    CARBS.FIXED THE FLOATS REINSTALLED CARBS,RUNS LIKE
    NEW! HAVE ALL THE POWER BACK! THANKS FOR YOUR HELP. PAUL "
Similar Threads
  1. Power trim vs power tilt
    By mac_55 in forum Chrysler Force Outboard Forum
    Last Post: 05-13-2011, 09:18 AM
  2. Replaced power pack now no power under load
    By marineman43 in forum Johnson Evinrude Outboard Archive
    Last Post: 09-08-2009, 11:17 AM
  3. No power or rpm forwardreverse tons of power and rpm
    By toad in forum Chrysler Force Outboard Archive
    Last Post: 10-17-2007, 02:11 AM
  4. 1981 90hp Johnson Power rating at prop or power head
    By jeffasmith in forum Johnson Evinrude Outboard Archive
    Last Post: 09-07-2007, 05:46 AM
  5. Tower of power power head swap
    By skoaljunkie in forum Mercury Mariner Outboard Archive
    Last Post: 01-26-2006, 05:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
