"Hi. I've recently acquire
"Hi. I've recently acquired an older 1989 4hp Johnson outboard. It will start running when you spray quick start into it. Anyways, it won't seem to pull gas from the float into the carb. I know there is a needle in there. How do I go about cleaning it to see if it is clogged? Does the fuel get sucked up through this needle and into the carb?
I am new to engine repair so any advice would be great."
