MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 3 of 3
  1. #1
    Join Date
    Jun 2008
    Location
    london, ont,, canada
    Posts
    11
    Default Had this boat for 2 months eve
    Had this boat for 2 months every trip always some letdown.Gas lines primers and hoses ;fuel filters;pluges ;wires. tonight oil alarm fishing got cut short.Ican't see any air bubbles in the lines.Can you tell me if i can convert bypass the oil tank ;mix my own oil and gas for this set up.
  2. #2
    Join Date
    May 2007
    Posts
    9,212
    Default "Vince the oil alarm does not
    "Vince the oil alarm does not tell you that there is a "problem" with the oil system, it simply is there to let you know when you are getting low on oil.
    The sensors are crap and fail regularly - but the oil alarm does not mean that you need to start mixing your gas.
    If the oil system fails, you will never get an alarm...."
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
  3. #3
    Join Date
    Jun 2008
    Location
    Posts
    11
    Default Thanks Graham. Oil levels are
    Thanks Graham. Oil levels are fine;mabe pump is weak or the sensor alarm needs to be replaced.
Similar Threads
  1. Yanmar 2GM20F Alarm failure 1994
    By dave14 in forum Yanmar
    Last Post: 12-28-2010, 05:33 AM
  2. Overheat Alarm 1989 60hp
    By fermdog69 in forum Johnson Evinrude Outboard Forum
    Last Post: 09-05-2010, 09:56 PM
  3. Hot Alarm without the engine even running? 1994 150hp
    By speakrdude in forum Johnson Evinrude Outboard Forum
    Last Post: 08-04-2010, 08:07 PM
  4. 1994 90 hp Mariner alarm
    By L Estal in forum Mercury Mariner Outboard Archive
    Last Post: 05-09-2007, 07:20 PM
  5. Nissan 60HP Alarm question
    By johnnyd in forum Nissan Tohatsu Outboard Archive
    Last Post: 05-23-2004, 10:41 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
