Results 1 to 3 of 3
  1. #1
    Join Date
    Jun 2006
    Location
    gainesville, georgia, usa
    Posts
    30
    Default "I have a 1978 mercury 80 hp,m
    "I have a 1978 mercury 80 hp,model 800,4 cylinder,s/n 5004670.i have replaced the water pump 4 or 5 times since i have had it with no problem.this time i replaced the impellar and can not get it to shift out of forward gear.with the foot off should i be able to duplicate the shifting by turning the shift shaft in the foot and moving the prepellar?i have the manual and have read it but can not make since out of it.it says to have your shifter in forward before you remove the foot which i did.any help would be great and appreciated.thanks in advance.you can call me if you could.thanks again,Bill"
  2. #2
    Join Date
    Jun 2006
    Location
    Posts
    30
    Default "phone number 770-718-9160,tha
    "phone number 770-718-9160,thanks again for the help,Bill"
  3. #3
    Join Date
    Jun 2006
    Location
    Posts
    30
    Default "thanks to ikia for the respon
    "thanks to ikia for the respone that helped me.worked grat.this board is great.thanks,Bill"
Similar Threads
  1. Replacing water pump on alpha 1
    By seaduction in forum Mercruiser Sterndrive Archive
    Last Post: 05-13-2008, 05:02 PM
  2. Replacing Alpha Gen I water pump
    By bloojeep in forum Mercruiser Sterndrive Archive
    Last Post: 02-14-2008, 09:12 PM
  3. Replacing Water Pump
    By gentt in forum Johnson Evinrude Outboard Archive
    Last Post: 07-12-2006, 03:39 PM
  4. Replacing Raw Water Pump on b89 ford 351
    By indmargreenhorn in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 07-11-2006, 12:17 PM
  5. Replacing water pump 8 hp mercury
    By Bill Felder in forum Archive 2003-2009
    Last Post: 05-21-2006, 03:12 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
