Results 1 to 4 of 4
  1. #1
    Default "Here is another issue that I
    "Here is another issue that I noticed while out on Saturday. In the picture you will see where the leak from near the block/head seam has made its way to the bell housing. The bubbling doesn't appear until approx 3000RPM's. Any suggestions?
    Bubbling from block/head seam
  2. #2
    Join Date
    Feb 2008
    Location
    Lake Norman, NC
    Posts
    227
    Default "I could not really tell anyth
    "I could not really tell anything diagnostic from pic, but oil from near head/block seam usually means a head gasket leak. However oil leaks are very sneaky and do not always show an exact trail to the source (exception - using a fluorescent dye marker) it could also come from a valve cover gasket leak. I'd check these areas very closely."
  3. #3
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Default Looks like a "rust thru
    Looks like a "rust thru" from a long time leak. Head gasket?
    Fix minor things (replace wear items for preventative maintenance.) that cause major problems before they break.
  4. #4
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,241
    Default "Ayuh,... I Donno,... I can
    "Ayuh,...
    I Donno,... I can't tell what I'm lookin' at, nor Where...."
Similar Threads
  1. Question on new Merc block...
    By hippie in forum Mercruiser Sterndrive Forum
    Last Post: 08-06-2010, 07:25 PM
  2. Merc 4.3 cracked block
    By lpedward in forum Mercruiser Sterndrive Forum
    Last Post: 04-16-2010, 12:43 AM
  3. Rear motor bolts on Merc 1986 57L Alpha1 drive
    By cruisers00 in forum Mercruiser Sterndrive Archive
    Last Post: 12-01-2008, 10:55 AM
  4. Using mixed block parts front and rear from 2 motors
    By Sleeper in forum Johnson Evinrude Outboard Archive
    Last Post: 03-01-2008, 12:18 PM
  5. Merc 454 overheated and cracked block
    By deltex in forum Mercruiser Sterndrive Archive
    Last Post: 09-26-2006, 08:13 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
