F
fastimz
Guest
"I am very frustated with my b
"I am very frustated with my boat and I need help. I have a 1989 Mercruiser 350 that is mainly stock. I have a Holley 4bbl and a mild marine cam. The problem I have run into is that anything above 3000 rpm's will cause the engine to die out. I can run all day with no problem below 3000 but if I get into it for about 10 seconds it will shutter then shut down. I thought it was a fuel issue so much as I changed the carb, fuel pump, all fuel lines, water sep filter and housing, pickup in the tank and added a clear filter so I could see what was going on with the flow. It ran good for the first 10 minutes out. Could run a little above 300 with put the cut out. "I fixed it" then it shut down, "dammit". I am now thinking it is going to be ignition. I'm leaning to the coil or Amplifier. It has the Thunderbolt IV system. How can I check this stuff so I don't have to keep buying stuff? Can I just run an HEI distributor and get rid of the whole system? Am I on the right track? Help."
