28 HP evinrude not charging
qlty
I have a 1995 28 hp evenrude.a
I have a 1995 28 hp evenrude.always shows 12 volts even at high revs.Is there a fuse I should check?I dont see one.Is there a procedure for checking the rectifier and the stator with an ohmeter?Thanks in advance for any help.
"yes there is.......i suggest
"yes there is.......i suggest a factory service manual.do a search,here,for checking rect....."
I have checked the rectifier a
I have checked the rectifier as per Joe Reeves procedure and it checks O.K.and all connections are tight.Still no charge to the battery??Any more suggestions are appreciated TIA.
"put a volt meter,...on batt..
"put a volt meter,...on batt.....get a static voltage...crank eng,get up to around 1000 rpm and see if it rises slightly...u r not going to see a huge rise,..just a little...if it rises any at all,it is charging...u might drain your batt a little prior to test..."
