T
Tom Farrell
Guest
" Dear Joe, thanks for the adv
" Dear Joe, thanks for the advice to take the boat into a competent mechanic. I had an erratic idle and was very concerned. I guess I had good reason to be, the mechanic found that 2 cylinders on my v6 outboard were firing intermittantly due to burned off insulation on wires out of the power pack. He stated that he was getting strange values on his meter out of the pack and I have authorized him to obtain a replacement. We have looked at the tach, and the reads at idle were very high, so we are going to run a temp tach when the new pack arrives to see what is up with the existing tach. He told me that some of the powerpacks fail and this can cause the engine to literally explode. Im wondering how the insulation on the wires got so hot, and the connections started to fail. We think that the previous owner ran the boat on flat batteries. Would this cause excessive heat due to the alternator running all the time to try to charge the dead sulfated batteries? So far the diagnosis of the charging system is fine. I know that I have a 35 amp alternator, and am running two group 29 die hard marine deep cycle/ starting batteries. I have a habit of running my engine for about 15 minutes every hour to keep my batteries up while I'm at anchor or drift fishing. what are your thoughts? thanks "
