"Lower Unit replace seals 1995
"Lower Unit replace seals 1995 Evinrude 48hp
I have almost completed my lower unit seal replacement. I have done the top seals (water pump, shift rod, etc) and replaced the screws. I am down to replacing the propshaft seal. I used Evinrude reseal kit #433550 as indicated in my parts manual. I removed back to back seals, but only have a single seal unit left. this seal appears to make a double seal as it has two springs in it. Is this the correct part? I assume I install the fatter end first, is that correct?"
