Results 1 to 3 of 3
  1. #1
    Join Date
    Apr 2006
    Location
    Mazatlan Mexico
    Posts
    1
    Default "What is the life expectancy o
    "What is the life expectancy of a C/N 6-33, in an Islander Freeport 41, with crusing speed of 6.5 knots @ 2,000-2,300 RPM?
    The engine is for propulsion only, battery charge, water making. Refrigeration is by generator.
    The engine oil/filers have been replaced every 150 hours, as well as fuel filters as needed.
    Engine starts on the first crank. A lazer temperature check shows 180 degees on each cyclinder. Recent oil analyses, show no fuel, anti-freeze or water.
    Repairs and maintenance have been carried out as recommended or has needed."
  2. #2
    Eddie from Oregon's Avatar
    Eddie from Oregon Guest
    Default Frequent oil changes can keep
    Frequent oil changes can keep engines going 30+ years. Note that engines run at fewer hours over a period of time might need changes at time intervals rather than engine hours. Be sure to use crackcase oil rated for use in diesel engines.
    On a diesel engines keeping fuel clean is more critical than in gasoline engines. Check and replace filters regularly. Keep fuel topped off to avoid condensation and use a biocide treatment in the fuel.
  3. #3
    Default Re: Life expectancy engine hours
    I have the cylinder head off of my 1972 SD 33, and got a gasket set (from Tiffin Parts in Ohio) that is for a 1980 and newer, even though I specified the earlier engine.
    It came with a lot (10) of rubber coated rings that look like they are the same size as the small copper gaskets for the injector tips, and some larger ones that look the same size as the upper copper compression seal on the injectors....the kit also has 6 small copper rings for the injector tip, but only two of the larger copper rings...it has a couple of some medium sized rubber rings too...
    I have a free copy of the service manual from the internet missing three pages (M 15-18) and tried to buy a copy but it is missing those pages too. The manual says "don't forget to install the rubber seals" in the head gasket...
    I have placed two of the large rubber rings in the head gasket at the rear end where they fit over what seems to be oil passages, and two of the medium ones on two passages forward of No 5 cylinder....there is another hole at the rear end of the gasket, that has a "stepped" end in the block, and there is one copper "compression' type ring that seems to fit there, but I am not sure about what is supposed to go there...So basically, I am missing a drawing of the head gasket that shows where the sealing rings go, and a list of the parts that are required...the 1980 gasket set has smaller valve guide seals too, but I cut the valve guides down and used a better type, so that seems to be ok...but it is frustrating not being sure about why there are so many of the rubber coated rings, and not knowing where they go...there are holes in the gasket that are the size of the small rings, but they are "blank" against the block and head...no passages in either, at those holes...should I put the rings there? are these a new type of injector seal? I took the head off because there was a lot of white smoke that smelled like unburnt fuel, but seemed to be water vapor, but the head gasket did not look "blown"...so I had it serviced, and now have this problem with the gasket set...any guidance would be appreciated.
    Robert
    [email protected]
    415 250 3214
Similar Threads
  1. Life Expectancy of BF200
    By Justin Elia in forum Honda Outboard Forum
    Last Post: 07-07-2010, 09:15 AM
  2. Manifold Life Expectancy
    By eselgar in forum Crusader Marine Engine Forum
    Last Post: 03-18-2010, 08:44 PM
  3. 671 TIB life expectancy
    By quite_the_ride in forum Detroit Diesel
    Last Post: 07-10-2009, 02:33 PM
  4. Engine life in hours
    By cc183 in forum Crusader Marine Archive
    Last Post: 10-17-2007, 12:39 AM
  5. Compression and life expectancy
    By cek1 in forum Yamaha Outboard Archive
    Last Post: 05-15-2006, 04:48 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
