S
Shawn Wright
Guest
" I've recently bought a 1
" I've recently bought a 1975 20Hp Evinrude which seems to run well, but like every Evinrude I can recall, has a stiff hand throttle. I disconnected the linkage at the top of the vertical shaft and determined the stiffness is between the grip and this shaft.
I then removed the grip and swivel arm, and cleaned and lubed, which made little difference, so the stiff section appears to be between the swivel section and the vertical shaft. Not surprisingly, the grease nipples at each end of this shaft are plugged...
Any tips on how to unplug a grease nipple?
Thanks. "
Thanks. "
