I have a 15 horse johnson.one
I have a 15 horse johnson.one day on the river the motor jumped from forward to reverse. I put into forward and a few minutes later it did it again. the motor seemed to run ok other than the shifting problem. by the time I was almost back to load the boat it quit running. I pulled the flywheel off and the key has sheared. could this be caused from going into reverse while cruising? or could it be going into reverse due to timing issue and backfire due to sheared key? about 3 weeks before I lost a prop on a tree in the river. but it ran fine for several outings after that until the shifting issue.could the shifting issue have just finished off a half way sheared key ? your help is appreciated
