A
astrong
Guest
" Got an old motor and 14ft bo
" Got an old motor and 14ft boat. Motor was running rough, with apparent low power esp at speed. I was about to replace plugs (the old ones seemed a bit oily), but the manual calls for UL-77 (I recall), but in the motor they were QL78JC4. Which should I use?
Further, I was checking why it might be low power/rough idle, and pulled the top wire - motor started and ran the same on the bottom cylinder only. Tried to start and run on top cylin only - nothing. Joe once mentioned top cylinder are easily affected by armature base problems under flywheel - is this possible a timing issue? Compression? Spark seems to the the same on both cylinders when checked at spark gap.
Any comments/suggestions on proper plugs and low power?
Thanks,
astrong "
Thanks,
astrong "
