"Alan,
As long as the beari
"Alan,
As long as the bearings are not damaged you can use the old ones.
Some Force wrist pin/bearing assemblies can be tough to take apart and assemble. If you have the type where the bearing collars fit very tightly on the wrist pin it will take quite a bit of force to remove the wrist pins. You have to insert a spacer when you press the wrist pins out so that the needles are not compressed by the collars, and possibly damaged. When pressing the wrist pins back into position, you must use the spacer again for the same reason.The spacer is inserted between the connecting rod and one collar.
Tony"
