eturnertdhca
"I recently purchased this mot
"I recently purchased this motor. It has been sitting on the boat outside for at least a year. When I opened the upper oil plug pressurized water came out and when the lower plug was removed, more water ran out before the gear oil started draining. I believe seal replacement is in order? Is it possible to replace the seals and related parts without removing the lower unit?
I have removed the prop and can see 3 small bolt heads inside. Should I be able to remove these and then remove the seal/bearing body? I have a manual coming, any help would be appreciated. What would a mechanic charge for this, roughly?
Ed"
Ed"
