Mercruiser Trim Pump
M
Michael Murray
Guest
"If not one thing, another, hu
"If not one thing, another, huh?
All done with the winter work on the boat, incluning cleaning all electrical on the mercruiser trim pump assembly.
At the controls, I can raise, but not lower, and no trim in either direction.
When I cross the solenoids, everything works.
Are these solenoids generic? I can't seem to locate just the trim assembly solenoids on line anywhere (unless someone has a part #), but it's configuration looks like my slave solenoid for my starter - would those work as replacements?
Thanks."
"Same problem last year, picke
"Same problem last year, picked up replacement solonoids at a marina for $13.00 ea. Buy a spare, the working one will probably be next. Bring the old one and they'll match it up."
"Mike, There are only a few d
"Mike, There are only a few different type of solenoids made for auto and marine use. The trim pump could easily use a solenoid similar(in appearance) to your slave solenoid. I think the Mercruiser price was about the same as the aftermarket price. I would use only marine solenoids. They are stainless steel and sparkproof, both of which are important."
