"I was given this information
"I was given this information by someone selling a left handed prop. The one I currently have is right handed. Is it true? I have a 2001 Glastron SX175 with a Volvo Penta 4.3GL/Gi Thanks, Brian
"All Volvo Outdrives can be change to run either a left or right hand prop. All you have to do is pull the back cover and move the shift linkage to the other side. You will also have to adjust the trim tab behind the prop to lean the other way (you will notice how it is offset to counter-act the push of the prop). Takes about 5 minutes""
