Results 1 to 3 of 3
  1. #1
    Join Date
    Mar 2006
    Location
    Jacksonville, Florida, USA
    Posts
    6
    Default "Last weekend the alternator b
    "Last weekend the alternator belt on my 2001 Mercruiser snapped. I bought a new one to change, however I realize that the belt must go through the engine mount, is this real or what? Is there any other way to get the belt through without undoing the engine monut? Or do I REALLY have to unbolt the mount? If yes, how do I do it without the engine colapsing!!!! Please help, I have promised my 6 year old daughter that I would get it fixed and came to find out is a little trickier than I thought."
  2. #2
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,052
    Default "Even tough you Don't say
    "Even tough you Don't say What engine you have in your 2001 Mercruiser,..........
    I'm Guessing it's a 3.0l......
    If that's the case,....
    There's a small block on the portside of the front motor mount that is removed, after you remove the 2 bolts holding it in place,.......
    The starboardside of the mount will hold the motor, until you reassemble the portside........."
  3. #3
    Join Date
    Mar 2006
    Location
    Posts
    6
    Default "Yes, it is a 3.0L and I appri
    "Yes, it is a 3.0L and I appriciate your response very much. I am going to try to locate the small block with two bolts and will let you know the result. Thanks!"
Similar Threads
  1. Alternator Belt
    By jumpin in forum Crusader Marine Engine Forum
    Last Post: 12-10-2009, 05:59 PM
  2. Mercruiser 50 LX AlphaOne Thunderbolt IV distributor question
    By kenmemphis in forum Mercruiser Sterndrive Archive
    Last Post: 04-15-2009, 09:57 AM
  3. 94 Cobra 50 Alternator Belt Replacement
    By Paul Walden in forum OMC Sterndrive and Inboard Archive
    Last Post: 08-03-2007, 11:50 AM
  4. 2003 bayliner 30 alternator belt replacement
    By steve carlson in forum Mercruiser Sterndrive Archive
    Last Post: 06-03-2007, 11:59 AM
  5. Mercruiser 30 alpha one LX alternator belt
    By Tommy Noles in forum Volvo Penta Gas Archive
    Last Post: 12-11-2005, 09:25 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
