Tilt trim assembly removal 135 black max S#OA993778
A
Alan R Wilkerson
Guest
large cylinder in the tilt/tri
large cylinder in the tilt/trim assembly has a (approximately) 1/2" pin with a slot on the port side that goes through a sleeve at the top of it .There is a small 1/8" pin run through the middle of it perpendicular to the larger pin.How do you remove the small pin first then how do you remove the large pin.
