"I am replacing the gear case
"I am replacing the gear case lube. There are many different options. Some cheap, and others very expensive (name brands). Is there a big difference? I was thinking of the cheaper “Starbrite” brand gear lube. Then I saw that “Starbrite” has a synthetic lube. Would the synthetic lube be better than the regular lube? Would the synthetic be better than the name brand regular lube?
What should I use???"
