Page 1 of 2 12 LastLast
Results 1 to 30 of 37
  1. #1
    Steve Elkins's Avatar
    Steve Elkins Guest
    Default Hi everyone. I have what I bel
    Hi everyone. I have what I believe to be an Elgin outboard motor. On the serial number plate it says Sears Roebuck & company. The serial # is 761.1853
    I was wondering about what year this engine is and does anyone have any links to online manuals? I'm also looking for the piece that covers the carb. Otherwise seems to run good.
  2. #2
    Steve Elkins Guest
    Default I think is 7 or 7.5 hp
  3. #3
    Steve Elkins Guest
    Default Found the year. Its a 1953 Elg
    Found the year. Its a 1953 Elgin 2 cylinder. Any ideas on gas/oil mix? 30-1?
  4. #4
    Join Date
    Jun 2006
    Location
    kenosha, wi,
    Posts
    1
    Default "Did you find a gas/oil mixtur
    "Did you find a gas/oil mixture? I have what i believe is a 1956 7.5 Elgin and can't find the mixture ratio information anywhere. Judging by your serial #, i also believe yours is a 1953 7.5. Mine is 571.5970. Please update if you find a ratio. I will too."
  5. #5
    Steve Elkins Guest
    Default I do have the correct mix at h
    I do have the correct mix at home..will update tonight.
  6. #6
    Howtheybitin's Avatar
    Howtheybitin Guest
    Default I have a 1957 7.5 Elgin. I am
    I have a 1957 7.5 Elgin. I am in need of a new impeller for it. Any ideas where I might find one?
  7. #7
    Brent Knotts's Avatar
    Brent Knotts Guest
    Default I have a 1977 johnson 35hp out
    I have a 1977 johnson 35hp outboard motor..and it runs good till you gas it and it acts like it is starving for gas...i put a new fuel pump on it and it still does the same thing.......i don't know what to do any answers?????
  8. #8
    Join Date
    May 2006
    Location
    Washington, Illinios, usa
    Posts
    2
    Default "im seeking service manual for
    "im seeking service manual for a elgin 2 1/2 hp model no. 571.58401 ser no. 401-38487 this motor was manufactured by west bend some where between 1946 and 1854 its water cooled any info appreciated thanks [email protected]"
  9. #9
    Join Date
    May 2006
    Location
    Posts
    2
    Default oops prvious post had incorrec
    oops prvious post had incorrect yr 1946 to 1954
  10. #10
    njl4's Avatar
    njl4 Guest
    Default "I have just acquired a 40 HP
    "I have just acquired a 40 HP Elgin Outboard Motor manufactured by Sears Roebuck.
    I do not know it's serial number. Is anyone able to advise what mixture of oil / fuel is required to run this.
    Also, is there a source of manuals for same ?
    Thank you."
  11. #11
    Dean Rodgers's Avatar
    Dean Rodgers Guest
    Default I have just aquired a elgin mo
    I have just aquired a elgin motor and know little about it so any information would be great. mod. number 571.58561 ser. number561.19809 Information such as year of make horse power and fuel mixture. If any information is given it would be greatly appreciated!
  12. #12
    Dave Walters's Avatar
    Dave Walters Guest
    Default "Fuel/oil mixture is 16:1 for
    "Fuel/oil mixture is 16:1 for the old Elgins. I have a 7.5 and need an idle screw and retining nut for my tillotson md109a carb. Or if possible replace the carb if someone has one. The # on mine is C571.597561. Can't find any info on this one. Most info can be found at the Elgin web site or the Antique Motorboat website. Parts are hard to find but try www.laingsoutboards.com for difficult to find parts."
  13. #13
    Bruce Elander's Avatar
    Bruce Elander Guest
    Default I have a 12hp 1957 elgin. I
    I have a 12hp 1957 elgin. I'm looking for a (11 tooth) pinion gear for the pull start. Anyone have any ideas where I might find one? Thanks
  14. #14
    Greg Marchand's Avatar
    Greg Marchand Guest
    Default "looking for an elgin water pu
    "looking for an elgin water pump impeller for a 7.5hp 1954 model number 571.58772 serial no. 772 22614 thanks, Greg"
  15. #15
    Brian Watkiins's Avatar
    Brian Watkiins Guest
    Default "HI, I have a old elgin out bo
    "HI, I have a old elgin out board i just got.It is a 7.5 horse and the serial numbers are 761.4940 does anyone have any information on what year it is,what is the gas mix and is it water cooled or not. Thanks for the help Brian!"
  16. #16
    John Owens 's Avatar
    John Owens Guest
    Default Hi I have an Elgin outboard Mo
    Hi I have an Elgin outboard Model #571.58761 from Sears Roebuck is 16:1 gas ratio the proper ratio for this motor
  17. #17
    Join Date
    May 2007
    Location
    Inverary, Ontario, Canada - The Great White North Eh!
    Posts
    9,114
    Default "What a mess of posts - most t
    "What a mess of posts - most times you will get better answers (or answers at all) by starting a new discussion.
    John (last thread) wrt your Elgin outboard, which is a 1953, twin, 7.5 built by Westbend.
    Many of these small engines ran at either 24:1 or 16:1 (16:1 most notably on the Tecumseh built engines).
    If the original sticker stating the mix is gone running at 16:1 won't hurt. If you find that your plugs get overly oil fouled, switch to 24:1 and keep an eye on them.
    You should mix regular unleaded with 2 cycle engine oil (such as used with chainsaws/lawnmowers) - NOT Marine 2 cycle oil...
    Others here should repost under "new discussion" if your questions go unanswered.
    Additionally, a good source for manuals and some parts on these old/discontinued outboards is www.discount-marine-parts.com"
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
  18. #18
    Joe Downing's Avatar
    Joe Downing Guest
    Default I have two Elgin 12 Hp outboar
    I have two Elgin 12 Hp outboards sn61601210 on one. both are in running condition. please contact me if you are interested.
  19. #19
    Tom Kargus's Avatar
    Tom Kargus Guest
    Default "I was surfing the net looking
    "I was surfing the net looking for info on my 1947 Elgin Model 571.58301, 1.25 Hp outboard.
    I found a website that stated most engines in that era use 1/2 to 3/4 pint of oil (TCW-3) per gallon.
    It also stated that most would also use a Champion J11C spark plug. I don't know if this thread is active but I thought I would throw that out there."
  20. #20
    Join Date
    May 2007
    Location
    Posts
    9,114
    Default "Tom, most of these little eng
    "Tom, most of these little engines will run fine at a mix of 24:1, but not with marine TCW3 oil.
    The air-cooled motors should use regular 2 cycle oil (such as used with chainsaws/lawnmowers).
    Some recommdations have come from Tecumseh, a prolific builder, that a mix of 16:1 also could be in order and in fact some motors even have a sticker on them with the 16:1 mix ratio.
    Your model was built by West Bend, exclusively for Sears. Sorry, can't help you with a plug listing, I don't have recommedations for West Bend's in my pile of junk, however, the J11C is a common small engine plug, still very much available..."
    Graham
  21. #21
    Join Date
    May 2007
    Location
    Posts
    9,114
    Default "Sorry Tom, early in the morni
    "Sorry Tom, early in the morning for me - should have read 16:1 above, not 18:1...."
    Graham
  22. #22
    bjmullins's Avatar
    bjmullins Guest
    Default "To be clear, I think you shou
    "To be clear, I think you should only use the TC chainsaw weedwhacker etc 2 stroke oil in the aircooled engines. Water cooled Elgins should use modern TCW-3 Marine 2 stroke oils.
    http://www.elginoutboards.org/elgin1946to54.htm"
  23. #23
    dogdays's Avatar
    dogdays Guest
    Default can anyone tell me gas mixture
    can anyone tell me gas mixture to the scott mccoullough outboard 1 or 2 hp made by sears tim
  24. #24
    Join Date
    May 2007
    Location
    Posts
    9,114
    Default "24:1 using regular unleaded g
    "24:1 using regular unleaded gas (86 or 87 octane) and normal 2 cycle motor oil, such as used with lawnmowers or chainsaws - not TCW-3 rated Marine oil - it's too thin for air cooled motors..."
    Graham
  25. #25
    Wendy Highsmith's Avatar
    Wendy Highsmith Guest
    Default "In cleaning out my parents ga
    "In cleaning out my parents garage, I came across a Sears Elgin outboard motor - Model #571.58401 (manufactured around 1947-1951). Any ideas how much it's worth - and, what would you suggest is the best way to try and sell it?"
  26. #26
    Join Date
    May 2007
    Location
    Posts
    9,114
    Default "Wendy you have your dates cor
    "Wendy you have your dates correct for sure. It's a little single cylinder 2.5 horse built for Sears by Westbend (who now produces kitchen appliances).
    Value? Not much. There is literally thousands of these 1940/50/60-something little air cooled motors out there.
    If it was in it's original box, never fired up etc etc it may be worth a few hundred bucks to a collector. As a used motor you would be lucky to get 50 bucks for it - and that's only if it's running.
    Put it on Ebay and let the "market" determine what it is worth.
    It's greatest value would be if you could use it yourself....."
    Graham
  27. #27
    Default Thanks for your prompt respons
    Thanks for your prompt response. Now I have to decide.
  28. #28
    gemp's Avatar
    gemp Guest
    Default "I have a 1967 7.5 hp, Elgin/S
    "I have a 1967 7.5 hp, Elgin/Sears outboard motor, manufactured by McCulloch, model number 57459520, 2 cycle, I am looking for a fuel line adapter from the tank line to the outboard motor. Would anyone have a part number or where I can find this part (new or used). Also wondering what the correct fuel mixture is for this motor and where I can find specs or owners manual. Any help appreciated. Thanks-Gemp"
  29. #29
    Default I have a old elgin i would gue
    I have a old elgin i would guess 2-3 hp the only # i can find is 303 23862 can anyone help me with year & horsepower
  30. #30
    Join Date
    May 2007
    Location
    Posts
    9,114
    Default "Jim, the Elgins were a Sears
    "Jim, the Elgins were a Sears store branded models built by either McCulloch or West Bend.
    To figure out exactly what you have would need you to find a model number starting with either 571 or 574..."
    Graham
Similar Threads
  1. 1952 7.5 HP Elgin outboard
    By propfool in forum Elgin Outboards
    Last Post: 04-15-2010, 03:50 AM
  2. 35 elgin outboard mid 60bs
    By stopper in forum Elgin Outboards
    Last Post: 10-09-2009, 08:11 AM
  3. 35 elgin outboard mid 60bs
    By stopper in forum Miscellaneous marine engine topics
  4. Old elgin outboard
    By jimn in forum Archive 2003-2009
    Last Post: 06-23-2006, 11:27 PM
  5. Sears 1968 9hp Elgin outboard
    By mike in forum Archive 2003-2009
    Last Post: 10-10-2003, 04:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
