318 timing cover needed
I believe these are the same a
I believe these are the same as the automotive covers so maybe a junkyard might have one. Don't know if they made a steel version. What happened to yours?
"I run my boat in brackish wat
"I run my boat in brackish water and over about 10 years ,i was getting water in my oil,the aluminum just could not hold up,i think a steel one would be the trick,i wonder if there is any after market timing covers?"
If aluminum is all that's
If aluminum is all that's available you could take it to a plating shop and get it anodized.
"Chris...Check out Hurrikain.c
"Chris...Check out Hurrikain.com, he should have what your looking for"
"I think i have found the righ
"I think i have found the right steel cover,now if i could find a steering cable for my 1969 Ski Nautique,it has the Teleflex Big T helm,and the cable is 17' long,can just make out the # stamped into it as, T 17 TT ,Thanks Chris"
check out marysvillemarine.com
check out marysvillemarine.com they have all the chrysler left overs from the factory. when you get on the site TYPE in chrysler and it will come up with all the parts.498 parts
