"This is to report a successfu
"This is to report a successful retrieval of the 'lost nut' under 'OMC Owner's Mistake Number Two Screw' on my 89 OMC Cobra drive. Here are a couple tips and pix that may be helpful.
1. I made a dolly from 2x6's and heavy duty caster wheels, with two angle strips to clamp down the stern drive plate. The eye bolt sticking up from the drain plug hole was something I added to use a chain host but ended up doing a dolly instead. Left it in while working anyway, it provided a handy 'handhold' to help maneuver the stern drive. Just don't tilt up the stern drive with the eye bold in, it could hit the back of the boat!
pulling the stern drive away on the dolly"">
I used the boat drive tilt switch to lower the drive so the plates were horizontal and just above the dolly, then used the boat trailer jack to lower it onto the dolly and attached metal angle strips to clamp the plates to the dolly. Worked like a charm, very easy to move. Go slow after removing the 6 nuts when you pull the stern drive away from the boat, and make sure the gasket doesn't tear (unless you thought ahead and have a new one to put in).
home-made dolly for removing cobra stern drive"">
2. It was easy to fish out the lost nut (see pic)
the lost nut as seen in the left stern drive water channel""> Putting it back in was harder to reach. I used an open end wrench to hold the flat nut (it's a bar about 1 1/2 inches long) and wrapped the end of the wrench holding the bar with electrical tape to hold the nut steady while inserting it (see pic). My wife also suggested cutting a piece of cardboard and sliding it in next to the wrench to prevent the nut from falling further into the stern drive through a water access hole.
using an open end wrench and electrical tape to hold and reinsert the nut"">
3. I looked for a leak, and the only obvious problem was the gasket where I removed the stern drive had a small tear/defect. Not having a new gasket on hand, I bought a couple tubes of blue gasket silicon (like formagasket) and applied that liberally to the defect and in fact over the entire gasket, before reattaching. Line things up carefully and slowly turn the u-joint if necessary while pushing in to reinsert the drive shaft into the boat motor spline, you may have to try this a few times before it goes.
line things up carefully and slowly spin the u-joint while pushing in to reinsert the drive shaft"">
This has shown no sign of leaking since, but I've only used the boat a few times so there may yet be some other problem and I'll check the oil for milkiness to be sure it's ok. At least now I have a nice dolly if the stern drive has to be removed again. "
