"Jeff;
OK, I missed that you
"Jeff;
OK, I missed that you are running an Alpha One. That may be true that the Gen II flows more water than an Alpha One. Gen II's were offered for a while with the 330 hp 454's.
A thru hull pickup sounds like your answer, and reinstall the belt driven pump. The belt driven pump flows about twice the water that a Gen II drive does. It's good you still have all those parts, right?
Don't take the drive impeller out. Leave it in and cut the hose from the leg to the transom plate. This will allow the impeller to still pump water up around the upper gear case. Essential to keep it cooled because when you are cruising the upper gear case is out of water, and will not cool properly without that pump flow.
Kurt;
The ECM that comes with the 6.2 MPI is properly tuned to deliver the required fuel for the 383. There are of course no jets to mess with.
Here's the thing though: The ECM is designed to run with the exhaust backpressure of a Bravo drive leg. I am running side hull exhaust outlets wih 4" exhaust hose connections, which is less restriction. I have noticed mine wants to miss a little in cruise range up to about 2800 RPM. I am guessing the mixture is a little lean in this range.
Above 2800 RPM it runs smooth and strong.
I have just put in a pair of Hardin 4" silencers to quiet it down a little. These will also add some backpressure, so I am hoping they will help the missing issue. Time will tell.
Jeff; what exhaust are you running with yours?
Rod"
