Click for Volvo Penta parts and manuals!
Results 1 to 8 of 8
  1. #1
    Join Date
    May 2008
    Location
    Milton, Ontario, Canada
    Posts
    5
    Default "I have a 1986 Bayliner Capri
    "I have a 1986 Bayliner Capri Cuddy with AQ225E / 275 outdrive.
    I am having a hard time finding replacement springs in Toronto, for my Prestolite distributor model # 841069. Does anyone have any thoughts as to were I can find replacement advance springs. There is no issues with this distributor except for the rusted out small spring. Any help would be greatly appreciated."
  2. #2
    Join Date
    Feb 2006
    Location
    Ladysmith, BC, Canada
    Posts
    5,862
    Default "Geoff, it is not a good idea
    "Geoff, it is not a good idea to just replace springs, as the advance curve may get affected: if too advanced, detonation may happen; if too retarded, the engine will lack power.
    Your best bet is to take the distributor to a shop where they can test it and install the correct springs so that it keeps the correct advance curve."
    [URL]http://www.grandmaraismichigan.com/Recreation/fisherman.gif[/URL]
  3. #3
    Join Date
    May 2008
    Location
    Posts
    5
    Default "Thanks El, I did some more se
    "Thanks El, I did some more searching on the site and found Lakeland Auto & Maine and gave them a call and they have the parts. Matched up by the IBM number 7013A and Bill was able to match the springs up and they have them.
    Thanks for you help.
    Geoff"
  4. #4
    Join Date
    Feb 2006
    Location
    Posts
    5,862
    Default "Geoff, I would still recommen
    "Geoff, I would still recommend that you get the distributor tested after you change the springs. You can either take it to a shop where they can put in on a test stand; or, if you have the factory advance curve, you can test it with a timing light with tachometer and digital advance featrues, like this one:
    http://www.amazon.com/Equus-3568-Dig.../dp/B000EVYGV4"
  5. #5
    Join Date
    May 2008
    Location
    Posts
    5
    Default Thanks. I do have the digital
    Thanks. I do have the digital advance on my timing light and a digital tach. but were would I get the factory advance curve info from?
  6. #6
    Default help.need apoints distributor
    help.need apoints distributor for a aq125a thanks daniel
  7. #7
    Join Date
    Feb 2006
    Location
    Posts
    5,862
    Default "Geoff, this is the draph for
    "Geoff, this is the draph for a 350 Chev. Use the darker line, as the others ("original" and "final") are from one of my distributors (before and after recurving).
    Please keep in mind that if you are going to use the timing light to verify the curve, then you have to add the static ignition timing at idle (8BTDC at 600 RPM) tot he values on the chart.
  8. #8
    Join Date
    May 2008
    Location
    Posts
    5
    Default This is a great help thank you
    This is a great help thank you.
    I will let you know once I get it set up.
    The engine has not ran for 4 years. Had pulled the engine half a apart so far and hope to have it running this weekend.
    Thanks again El!
Similar Threads
  1. Prestolite distributor springs
    By LeisurLee in forum Marine Power Engine Forum
    Last Post: 08-09-2012, 10:30 PM
  2. Mechanical advance springs 1988 5.7
    By duo_prop_dad in forum Volvo Penta Gas Engine Forum
    Last Post: 08-22-2010, 07:36 PM
  3. distributor advance springs 318 225 hp
    By loid58 in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 08-19-2010, 08:17 AM
  4. Prestolite distributor advance springs
    By 76luhrs in forum Crusader Marine Engine Forum
    Last Post: 08-02-2009, 07:31 PM
  5. Springs for Prestolite distributor centrifugal advance weights
    By joysea in forum Volvo Penta Gas Archive
    Last Post: 04-13-2008, 07:10 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
