"Robert -- what we need to kno
"Robert -- what we need to know is when you have this problem how long has the engine been turned off. In other words when you get to your boat, you obviously need to prime it. You go out fishing and sit for 10 minutes in one spot. Do you need to prime it again after a 10 minute sit? If you do, fuel is either draining from the carbs or its draining back to the tank. After a 10 minute sit, there should be enough fuel in the carbs to start it even if the fuel in the line drains back. It also doesn't matter if your fuel line is brand new. Brand new things can be defective. Try positioning the fuel line so the primter bulb is vertical rather than horizontal. And above all, make sure your starting procedure is correct (proper use of choke and throttle)."
