"Hello, I have had this engine
"Hello, I have had this engine rebuilt recently,only done 20min running, and when i took it to a mechanic to have it checked out because it was not starting properly[not the person that rebuilt the engine] he has done the compression check and all were fine,he did a tank test and the thing stopped after 5 mins running at 1800 rpm , he them rang me to tell me that the engine had seized,and to take it back to the engine rebuilder which i did ,the second mechanic had used his own fuel which on taking a sample has turned out to be very poor quality,small amount of water and sand smells like turps,it has made rather a large score up the inlet side about 4mm wide and 40mm long not really consistant with the lack of oil in the fuel i do think there was some in there but how much i dont know, is it possible that a ring has broken, maybe denotated with this old fuel and caused this, there didnt seem to be much of a hone mark in the bores for 20mins running not sure if he did the the ring gaps either could someone guide me on this one thanks."
