b94 Yamaha Side Mount Remote Control
boaterbob
"I would like to replace the s
"I would like to replace the shift/throttle and the neutral speed control cables on my Side Mount Remote Control (like the 703 Single Engine Type, but a 1994 model). Are there any springs, detent balls, etc that are going to 'spring' out when I disassemble the side mount remote and leave me with no idea where they need to go back to, or can I remove the box and just lay it on its side and take the cover off? The neutral speed lever does not do anything (although I can move the control on the engine when the cover is removed from the engine and that works as it should - revs the engine when in neutral. The shift/throttle cable is split and rusty and thus stiff but it does work. I don't want to take the side mount single arm remote control cover off if things fall out when I lift the cover off.
Anyone already done this and can provide instructions?
Thanks in advance"
two phillips screws bottom cov
two phillips screws bottom cover will remove easy access to cables do not have to take box completely apart easy job
