followingsea
"E.P. and others,
I've
"E.P. and others,
I've been watching this Weber Carb swap discussion for some time now. There was a guy who did his own version with a friend building the adapter last year. It sounded like he was well pleased with the outcome.
Here's where I'm at on my project. I'm almost ready to do sea trials on a total restoration project on a 17-1/2' Campion (former hardtop that now has a mini-cuddy about 2' forward for more deck space aft).
Long story short the motor is an AQ140 now temporarily converted to a single Solex downdraft with matching VP manifold. Making it, in effect an AQ125A with an oil cooler.
A machinist friend set up a CAD/CAM program and machined an excellent aluminum adapter to match my rebuilt Weber 32/36 DFAV carb to the factory manifold (The Weber is jetted for the same size--in CC's-- but for an Automotive application). It will have the flame arrestor and tube from fuel pump, etc..
I'm hoping that if I set this up right, the boat can run on the primary 32mm most of the time and only kick in the secondary 36mm when I need an extra boost for a straight run out and back to a fishing site. That's the plan. Hopefully this should squeeze a little extra out of each gallon of gas. We will see as it progresses.
Any further insight concerning making up some Push/Pull linkage that sits near the carb would be appreciated. My cable extends out when the throttle control is pushed forward and it needs to pull down or back to open the throttle on the little (temp) Solex OR the Weber replacement. I've got a pretty good plan for my homebuilt linkage version, but always open to better ways to do it."
I've
"E.P. and others,
