centurioneclipse
"I have been chasing this prob
"I have been chasing this problem for awhile. The boat runs fine above 1500rpm(planed out). Although it is really using way more fuel. I obtained a service manual. It says it should Idle at 600rpm. It idles a little below and rough. If it is run hard(say 36-3800rpm thru the slalom course) the idle is rougher and slower when you go to idle. I checked for error codes and there were none(only code 12). It has the MEFI3 ECM. I have verified timing(in service mode). Replaced plugs. They verified it is running rich. I went through the IAC functional test. (that is the 1st step after OBD and visual inspection in the "rough, Unstable, incorrect idle fuel injection troubleshooting chart. This test has you record RPM at warmed up idle, then turn off engine, disconnect IAC connector, restart engine and record RPM. If RPM is NOT > 200rpm MORE with IAC disconnected and all 4 iac harness terminals pass light blink light is says to replance faulty IAC. Now what bothers me is how rich the boat is running. can a bad IAC cause it to run rich? I thought it just controlled idle speed? Can any of you experts concur that a bad IAC can cause this? Since it failed the test should I just buy the damn thing like it says?"
