bushwhacker
"Alright. I didn't know to
"Alright. I didn't know to drain my block last winter, spent over 8,000 so far. Got a new motor in, remanufactored mercruiser marine engine. I watched the guys at a shop in Havasu, AZ put it in. Came back home to Pinedale, WY(which is 7,500ft. elevation) and went to run it on the lake. They set the timing there in havasu as well. it idled fine once they got it set. So We got it out on the water, got engine temps up to 160F. Got up to 1800RPM and backfires constantly. Tried advancing the timing and only got worse. Tried retarding timing, killed motor. So today, I took the carb off, I needed to change the jets anyways. It had 1.55mm in and its running way rich, so I am goin got try 1.50mm and if'n thats still too much, go to 1.45mm. Carb wasn't gunked up like I had hoped, cause that would be easier to deal with. But I pulled the carb and am cleaning it. pulled the plugs, and they're barely black, not sooted up. Just trying to figure out what to do next, cause I treated my fuel last year before storage with Stabil, but could that cause this exstensive backfiring? Some other people think the distributer is cracked or rotor plate is cracked, My engine came from US Engines in Kent, Washington. Is there a possiblity that the timing chain is off a tooth with the crankshaft, cause those guys at US engines seem to know their crap, so i doubt it. The engine came long block assembled. So Im not sure where to go from here, any ideas? Thanks alot guys."
