Single Cylinder Diesel
T
Tony Pernas
Guest
"Does anybody know what engine
"Does anybody know what engine this is?
"Hi there!
It could be eith
"Hi there!
It could be either Lombardini (Italian), Lister (British) or Hatz (German).
There are a few other manufacturers that does marine applications, but those listed above are most prominent.
See if there are any logo's on the block or head. This would help to identify the motor if you search websites of said manufacturers.
Happy hunting!
Kind regards from a chilly and wintry Johannesburg in South Africa!
Benjamin."
I can't find a thing on it
I can't find a thing on it except the folowing #'s : 190616060 280 and lower on the case 434
The starter is a ducel and I looked at some on line photos of the engines you mentioned and none appear close.
I found RMG Stamped on the blo
I found RMG Stamped on the block if that helps
"What make boat is it in? The
"What make boat is it in? The manufacturer or country of origin may be able to tell you something.
Due to the color,it could be a Yanmar."
