Water pump weak repost
scrub
"hi guys sorry for the lack of
"hi guys sorry for the lack of info , the motor is a a 93 120 v-4 oceanrunner, and was pumping very weak to me out of the pisser so i changed the water pump and not alot of difference?"
Run a piece of weed wacker lin
Run a piece of weed wacker line up the hose to try to clear any obstructions. Mud daubers love to crawl up them and clogged them up.
"90 Degree looper 120/140'
"90 Degree looper 120/140's are 'weak' out of the tell-tale due to the automatic draining pump system out of the cowling. Works like an ejector pump.
Take out clean and check Your thermostats (vernaterm) and membranes that they are working properly. The pin in the vernaterm has a tendency to be stuck open.
Start the engine and check temp on both cylinder banks. At idle, even temp, barely to touch when putting hands on top of each cyl bank."
