"I have a 1986 AQ131A which I
"I have a 1986 AQ131A which I have done quite a bit of work to New timing belt, Tensionor,Electronic ignition,Cap,Plugs,Rewired all electrics in engine new breakers new relays new wires.I tested boat last year and it seemed to get to 4500 RPM.Then I winitrized full tank of gas put in Stabil,wrapped up all electical connections and routed them to a watertight box installed in engine compartment,retimed engine now the engine starts fine idles fine runs fine up to 2400 RPM then seems to lose power backfires and seems to be starving for gas it is much worse under a load cant figure out what happened between this year and last any ideas would be appreciated"
