Results 1 to 4 of 4
  1. #1
    Join Date
    Sep 2006
    Location
    Riverview, FL, U.S.A.
    Posts
    26
    Default "What would I need to replace
    "What would I need to replace if I make the Alpha to Bravo conversion? Need to replace the outdrive, and I like the Bravos."
  2. #2
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,419
    Default "Ayuh,.... [b]Everything[/b
    "Ayuh,....
    Everything from the rear motor mounts, Aft, will need to be Replaced with Bravo parts,...
    Along with a few things mounted To the motor...."
  3. #3
    Join Date
    Sep 2006
    Location
    Posts
    26
    Default "mine's a 27' mid engi
    "mine's a 27' mid engine, so I have a 6 ft drive shaft. Is the bell housing and the transom mount both different?"
  4. #4
    Join Date
    Dec 2006
    Location
    Posts
    5,419
    Default "Ayuh,.... Everything bolte
    "Ayuh,....
    Everything bolted to the Transom is Different....
    You'll also need a motor mounted raw water pump..."
Similar Threads
  1. replacing alpha one with a bravo drive
    By ripboat in forum Mercruiser Sterndrive Forum
    Last Post: 12-26-2010, 11:41 AM
  2. ALPHA VS BRAVO MEASURMENTS
    By dream_wet in forum Mercruiser Sterndrive Archive
    Last Post: 09-16-2009, 12:33 PM
  3. Alpha Gen 1 swap to Bravo
    By lil_freedom in forum Mercruiser Sterndrive Archive
    Last Post: 08-29-2009, 06:47 AM
  4. Alpha 1 gen 2 to Bravo 3
    By baytro23 in forum Mercruiser Sterndrive Archive
    Last Post: 11-28-2007, 07:25 AM
  5. Switching mer alpha to mer bravo
    By mikescribner in forum Mercruiser Sterndrive Archive
    Last Post: 07-06-2006, 06:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
