MarineEngine.com - Your online store for all types of marine engines and boat parts.
PHONE ORDERS
Monday - Friday
9:00 AM - 5:00 PM EST
Click for TOLL-FREE Number
Secure Online Payments
Special $9.95 Flat Rate Shipping
(800) 209-9624 | Home | Contact | Shipping | Returns | Cart View your shopping cart.
Search by Part Number
Enter engine/drive part number.
Original & matching parts for sale.
Manuals & Accessories
Shop by description, item number
or manufacturer's model number.
Why shop with us? Check our reviews! Why Us & Reviews   Boat Repair Forum Boat Repair Forum   Boat Video Gallery Video Gallery
Results 1 to 5 of 5
  1. #1
    Default i have a 15ft Lowe prowler pro
    i have a 15ft Lowe prowler pro with front and rear casting decks. The boat is rated for 40hp max but has a 35 seahorse standard shaft. What does the motor weigh and wold a 180 pound 40 horse be better adding more weight and only 5 more horses?
  2. #2
    Join Date
    Jan 2005
    Location
    Goteborg Sweden
    Posts
    117
    Default "Not much of hp increase. Star
    "Not much of hp increase. Start to try to find the optimum propeller pitch. 5000-5500 rpm ar WOT.
    By the way, the max rating has always a safety factor and can be exceeded somewhat if necessary (I'm using a 70hp on a 50hp rated boat).
    Robert"
  3. #3
    Default so would it be worth keeping t
    so would it be worth keeping the 35 seahorse and spending the $600 to fix the lower unit or install the VRO 40 i already purchased. Im wondering if the 50+/- pound difference is worth adding the 5 extra horses.
  4. #4
    Join Date
    Jan 2005
    Location
    Goteborg Sweden
    Posts
    117
    Default "If you already have the 40hp,
    "If you already have the 40hp, why not use it?
    You get 14% hp increase, with a weight increase of 5-10% (total boat weight?). Performance should be at least as good as before.
    I can't tell if it is worth spending $600 on the old motor. Depends on the value after it is done.
    Robert"
  5. #5
    Default Thanx for the replies Robert.
    Thanx for the replies Robert. I really appreciate in insight. I bought the 40 already and it looks brand new inside and out from an older gentleman. My only conscern was the size difference from the 35 to the 40. The boat is rated for 40 max but being a small boat and a large guy i wasnt wanting to decrease my max weight rating with the same or lesser performance. The 35 is worth fixing the lower unit on it cause it too purrs like a kitten but for $400 more i got a complete turn key engine. Im gonna go ahead and run the 40 and can always add a speed prop if in need more but i figure 25-30mph in a 15ft flatbottom LOWE is sufficient. So if anyone is interested i have 1981 35 seahorse with cables/controls and a brand new Cabelas brand stainless steel prop for sale. The lower unit needs rebuilt but the drive shafts are still good and reusable(as quoted from Nate and Jeff and Lawsons Landing at Dillons Beach CA).
Similar Threads
  1. Weight
    By gcook in forum Johnson Evinrude Outboard Archive
    Last Post: 02-13-2008, 05:28 PM
  2. Weight of DT 150 EFI
    By greyduk in forum Suzuki Outboard Archive
    Last Post: 01-09-2008, 02:16 AM
  3. Motor to boat weight ratio
    By wvidal in forum Johnson Evinrude Outboard Archive
    Last Post: 04-16-2007, 09:16 PM
  4. HP to boat weight ratio
    By hivoltg30 in forum Johnson Evinrude Outboard Archive
    Last Post: 08-08-2006, 12:43 AM
  5. Weight
    By donald townsend in forum Johnson Evinrude Outboard Archive
    Last Post: 03-29-2006, 04:21 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
