"This is always an interesting
"This is always an interesting question.
If you are talking just the block that should be no problem.
But you should check both blocks over side by side closely to make sure that all the holes etc you are going to need for accessories, motor mounts, etc are there on the automotive block.
As far as internals, a marine cam is different, and I suspect the pistons, rings and rods are different. Marine engines use stainless head gaskets, and brass frost plugs instead of steel, just as examples. The flywheel may also be different; perhaps someone else here knows this for sure.
For my money I would find a rebuilt engine with marine spec components, and avoid the aggravation. What's wrong with your current marine block?
Rod"
