overdrivegear
"I need to fix the oil slick t
"I need to fix the oil slick that is coming from my 270 outdrive. The U joint has quite a bit of knock in it and I suppose that has caused the seals to oval in the upper housing and let gear oil leak out. Is there a common problem or something that is the usual suspect when oil leaking occurs (kinda like the elbow gasket overheating problem)?
Also, where can I find a new U joint and seals that won't break the bank?
Thanks guys."
Thanks guys."
