"Sorry for the delay,Al.Had so
"Sorry for the delay,Al.Had some things going on.A lot of questions you have to answer in one night.Look at the firing order of each engine.One will be 18436572...this is the LEFT hand rotation which is what most people have, or the most common.This engine should have a timing chain.The other engine is the RIGHT hand and I think Crusader changes it's direction by installing timing gears in place of the chain.Never had one apart to be sure, but from the way the parts are turning,this is what I think you will find.If this is the engine in question,there is a lot going on inside that timing cover.Did you winterize this engine yourself and was it run on land to do this?Hydro-lock can bend rods,but with this many I do not think you could start it as it would be just that...locked.
Here is what I think I would do if I was you.Only my opinion.Since you are this far into the engine,you want to not have issues all year,mess up parts not knowing whats up for sure,I would pull those heads as I would want those heads checked.Now you can see the top of the pistons as well to make sure all is well there.Only a few more bolts from where you are at now.If there is no signs of any damage in this area, your bottom end should be just fine.I would drop that oil pan if there is enough room,to check for loose metal and pull the timing cover and replace whichever is there.All this can be done in the slip.I know its a bending and carrying on,you have proven to be a man with determination to have things right.My take of this is that the one stone you do not roll over will be the one that hits you next week.Once right is better than 2 almosts.You always do have the option of pulling the boat at that fee also, but the engine is still at the same place.Keep in touch-just trying to help,Al....Todd"
