Rectifier on 1987 90hp evin
"wont harm the eng,..may harm
"wont harm the eng,..may harm the chrging system...why do u want it disc......it charges your battery if working properly.if u have a bad rectifier,..replace it."
"thanks for your answer, it ha
"thanks for your answer, it has not charged the battery in years but now I think its shorting at idle speed so if I disconnect it I'll be back where I was before it shorted. a new one costs $295.00 and I only use it occasionly."
"because the rpm's drop fr
"because the rpm's drop from 1100 to 600 and it shakes like it's on one cylinder then shuts off, when I disconnect the rectifier it runs smooth and when connected it runs up to 1200 to 1500 rpm's then the tach drops to 0 and stays until engine is slowed, then it picks up at about 1400 rpm. it also runs smoother when it's disconnected. what do you think? Harris."
