AQ131A coolant hose replacement
avent
"I have an AQ131A. It develope
"I have an AQ131A. It developed a pin hole leak in the large hose that runs from the heat exchanger to the water circulator (water pump). I can not for the life of me locate a part number, a picture of the hose or a dealer that can get one. Does anybody have any ideas where I can get this part or what the part number is? The hose has an inner diameter of an inch and an Eighth and has a sharp almost "U" style form to it. This makes it impossible to replace it with something from an auto parts store. Any help would be much appreciated."
"Does that hose connect from w
"Does that hose connect from water circulator to the heat exchanger (the part that holds antifreeze)?
I should explain I am new to boat motors, I keep wanting to call that thing a radiator."
