D
divedeep
Guest
"I am getting a high temp alar
"I am getting a high temp alarm when at high RPM's. I have replaced the water pump, t-stat's,poppet valve, and head gaskets. This has not helped in any way. Idle up to around 3600RPM no issues. Water pressure at idle 3psi and builds to around 6-7psi at 3600. When above 3600 the water pressure falls to 4psi. I did a compression check all is good 115-120psi. Any ideas on what could make the pressure fall instead of increase? Before this issue, the water pressure would average 12-14 psi at high rpm's.
Any help would be appreciated."
