I have an 85 merc 150 xr2 blackmax. It's a 6 cylinder motor, but has 2 send units each controlling 3 cylinders. At ide I had power to all 6 spark plugs, but put it under load and only 3 cylinders were firing. Likely one of your send units needs replaced. The engine actually is designed to run 3 cylinders at low throttle (no wake speed), and then engages the other 3 when you want to get on plane. Your other 3 cylinders aren't firing, thus the low speedDid anyone figure this out mines doing the same checked carbs checked spark took fuel pump off it’s pumping but not a great amount or at least I don’t think it’s a good amount I put my finger over the vacuum hole and didn’t feel anything was also wonder if I can plug that hole and electric pump it and I have one reed slightly open the rest closed I’m stumped
