Results 1 to 5 of 5
  1. #1
    Default "I purchased this the other da
    "I purchased this the other day for $20 bucks, took it home put some gas in and it fired right up! I know nothing about engines, have a feeling it needs a tune up. Was told it was a 2hp. Any idea what it is???
    http://i277.photobucket.com/albums/k...aas/front.jpg"
    http://i277.photobucket.com/albums/k...as/ground.jpg"
    http://i277.photobucket.com/albums/k...oundclose.jpg"
    http://i277.photobucket.com/albums/k...taas/prop.jpg"
    Also, i see a tube by the prop i assume is the impeller but no water is coming out of the engine any where while its running? is it clogged or is the tube for some thing else??
    http://i277.photobucket.com/albums/k.../impeller.jpg""
  2. #2
    Join Date
    Jan 2008
    Location
    black creek , ga,
    Posts
    180
    Default get us a serial number and we
    get us a serial number and we can tell you more
    Every day is a new day.....GO FISHIN
    Scott
  3. #3
    Join Date
    Jul 2006
    Location
    , Ontario, Canada
    Posts
    230
    Default "Hey John, Your motor is air
    "Hey John,
    Your motor is air cooled (you will see lots of fins on the cylinder), but the bottom (exhaust gasses) is cooled by the forward motion of the motor. That is why the water scoop is there. My first guess would be that it is about a 3 1/2 horsepower motor, but like Scott said, get a serial number if you would like more information."
  4. #4
    Default "On a little tag on the engine
    "On a little tag on the engine i found this...
    T-634-07d
    4795135
    also what should i do for a 'tune up'?
    -do i need to grease any thing?
    -take any thing apart and clean it?
    -should i replace spark plug and where do i get one?
    -what kind and how much oil to gas (i assume regular 2 stroke, not marine).
    I know nothing about engines but point me in the right direction and i'll figure it out. I took the cover off and it looks like a lawnmower engine. I'm sure i can take it apart and get back together pretty easy with out messing it up if i know what to do once its apart. Thanks!!!"
  5. #5
    Join Date
    Jan 2008
    Location
    black creek , ga,
    Posts
    180
    Default my charts show that block #634
    my charts show that block #634-07 as a 5.0 hp motor that uses a j-8-j or match plug and 16:1 oil mix and dont use marine oil use lawnmower 2 cycle oil.
    Scott
Similar Threads
  1. Uploading Pics
    By yahoo50 in forum OMC Sterndrive and Inboard Forum
    Last Post: 08-04-2009, 08:04 PM
  2. Posting pics
    By oldshore in forum Volvo Penta Gas Archive
    Last Post: 05-25-2009, 08:33 PM
  3. Air silencer pics
    By nicknack2 in forum Johnson Evinrude Outboard Archive
    Last Post: 04-28-2009, 05:11 PM
  4. Ok so what outdrive do i have on my 84 pics
    By weider1717 in forum Mercruiser Sterndrive Archive
    Last Post: 09-10-2008, 10:16 AM
  5. Looking 4 sterndrive pics
    By jayson in forum Mercruiser Sterndrive Archive
    Last Post: 07-30-2008, 01:57 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
