MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 5 of 5
Thread: Kill Switch
  1. #1
    Nelson Fletcher's Avatar
    Nelson Fletcher Guest
    Default I have a 20 hp mariner a701409
    I have a 20 hp mariner a701409 and I have spark issues the question is when I disconnect the blk/ylw kill wire and do a continuity test from it to ground I get nothing with button pushed or not but I also dont get spark when its disconnected when it was running a couple of days ago kill worked fine any ideas?
  2. #2
    Join Date
    May 2007
    Location
    Inverary, Ontario, Canada - The Great White North Eh!
    Posts
    9,117
    Default "Nelson, with the kill disconn
    "Nelson, with the kill disconnected and still getting no spark (on either cylinder) - that indicates that your problem lies elsewhere.
    No spark on either plug could be bad stator, bad trigger (more common) or bad switchbox (another likely candidate) - that is assuming that all your ignition wire connections are in decent shape...."
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
  3. #3
    Default "Ohmed out the stator and trig
    "Ohmed out the stator and trigger are goos so it looks like the switch box is the candidate, I also noticed the blk/ylw from the switchbox this morning had continuity to ground as the day warmed up it does not now, so thats likely the thing, switchbox is done :-("
  4. #4
    Default Now when I ohm it out today I
    Now when I ohm it out today I get nothing from the trigger wtf?
  5. #5
    Join Date
    Nov 2005
    Location
    , il,
    Posts
    2,198
    Default "when you ohm it out it must b
    "when you ohm it out it must be disconnected, wiggle the wires when you do to look for a broken lead. The stator usually either works or it doesn't. pull flywheel for a look"
Similar Threads
  1. Neutral safety switch versus shift kill switch?
    By Pal in forum Mercruiser Sterndrive Forum
    Last Post: 10-26-2010, 01:32 AM
  2. Kill switch
    By martyk in forum Johnson Evinrude Outboard Forum
    Last Post: 04-11-2010, 10:26 PM
  3. Kill switch
    By bcf45 in forum Johnson Evinrude Outboard Archive
    Last Post: 05-10-2009, 10:48 PM
  4. Kill switch
    By kodi in forum Johnson Evinrude Outboard Archive
    Last Post: 11-06-2006, 11:15 PM
  5. Kill Switch
    By dervin in forum Outboard motors archive 2000-2004
    Last Post: 02-24-2003, 03:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
