younggunner85
Ive had this boat for a couple
Ive had this boat for a couple of years and this if the first time ive had this problem and it has happened the last two times i went out. Whenever i get up to the top rpm range it will suddenly drop down in rpm quickly and then rev back up again. It goes from like 5000 rpm to 3000rpm and then back up again. It acks like its not getting enough fuel but i replaced the plugs and fuel filter and it still does it. It does it when the tank is full and it gets worse and less fuel is in it. Also it only does it when the engine in the water ive ran it out of the water at high rpm and it dosnt want to act up has anybody else had this problem.
